PVC valve and hose help pls!
Old Sep 2, 2013 | 10:03 PM
  #51
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: PVC valve and hose help pls!
Its really hard to say what's causing the rich condition, tapping on the ecm case to see if it causes the car to stumble, or hooking a scanner to look at the cts and or even if a injector is not flowing enough fuel the o2 will see this as a lean condition over compensation driving the injector to make the engine run overly rich.
Old Sep 2, 2013 | 10:31 PM
  #52
saldav420's Avatar
Car: 86 bronco, 88 iroc
Engine: 351 windsor, 350 tpi
Transmission: 700r
So in your opinion the problem is my camaro is running rich? Does any of the wirerying I described cause any rich running issues? And is the ECM the main computer under the pasenger side dash. Or is it the one near the fuel pump relay.
Old Sep 2, 2013 | 11:12 PM
  #53
Engine: Lb9
Transmission: M20
You stated the smell of fuel, The ecm is under the dash on the drivers side.
Old Sep 3, 2013 | 11:03 AM
  #54
saldav420's Avatar
Transmission: 700r
Yes I think I made a pin hole on the tank when I cut open a hatch to get to fuel pump, found the ecm a big square box and it was under the passenger side dash.
Old Sep 3, 2013 | 11:19 AM
  #55
saldav420's Avatar
Transmission: 700r
What do you mean hooking up a scanner to look at the cts, what's the cts? And just to let you know the ninth injector is not even connected.
Old Sep 3, 2013 | 06:00 PM
  #56
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Not connect to the wiring or not connected to fuel rail?
If the CSI is still connected to the rail and it is leaking then it will flow fuel into the engine regardless of whether it has a elec connection of not
Old Sep 3, 2013 | 06:04 PM
  #57
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You get a shop to connect a scanner to the computer so you can see exactly what the computer is seeing from the sensors it uses and what they are doing.
The CTS is one of the most important sensors; it tells the computer what the engine temp is so it can adjust the amount of fuel supplied.
More when engine cold , less when hot.
If the computer is being told the engine is cold it will put more fuel in (rich ) than what the engine needs
Old Sep 3, 2013 | 06:14 PM
  #58
saldav420's Avatar
Transmission: 700r
Its not connected to the wiring.
Something is really weird I disconnected the harness that goes to the fuel pump relay since I was going to soder them correctly. Was not connected for an hr or so, my next door neighbor came over and ask me what was going on so I told him that the car wouldn't stay on. So to show him what I meant I had him crank it and it turned on with the relay harness not even connected to the relay. I'm going crazy over here how could it turn on with that harness b not connected?
Old Sep 4, 2013 | 01:40 AM
  #59
saldav420's Avatar
Transmission: 700r
Is it normal for the ecm to be very hot?
Old Sep 4, 2013 | 04:21 AM
  #60
Engine: Lb9
Transmission: M20
The ecm shouldn't be very hot to the touch.
Old Sep 4, 2013 | 10:19 AM
  #61
saldav420's Avatar
Transmission: 700r
What does it mean if it's very hot?
And if I were to buy a new one would I just plug it in like the old one or anything special?
Old Sep 4, 2013 | 06:02 PM
  #62
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So if the CS Iinjector is faulty and leaking it will be letting fuel through anytime the pump is running
Only way to check it would be to remove and plug the supply line to the fuel rail
Something is really weird .... it turned on with the relay harness not even connected to the relay.
Perfectly normal.
There is a separate switch on the engine operated by oil pressure that runs the fuel pump as a backup should the pump relay fail.
This is why a factory service manual is essential when trying to work on your car so you understand what is what
Old Sep 4, 2013 | 06:57 PM
  #63
saldav420's Avatar
Transmission: 700r
So even if the CS injector is not connected (the wire harness) would it still be leaking? I also noticed that when the temp goes up on car is when it doesn't want to turn on.
Old Sep 4, 2013 | 08:59 PM
  #64
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So even if the CS injector is not connected would it still be leaking?
For sure ,it is only a valve turned on by power.
If the injector is locked in the open position ,having power or not won't make any difference; fuel will still come out anytime the pump is running .
As already noted ; only way to see if it is the problem is to disconnect the fuel line to it
FWIW ,
the CSI only has power when the engine is being cranked over
Old Sep 5, 2013 | 01:11 AM
  #65
saldav420's Avatar
Transmission: 700r
How do I test the CTS sensors once I take them of the block?
Old Sep 5, 2013 | 09:33 AM
  #66
Engine: Lb9
Transmission: M20
The cts is a thermistor , The resistance will change dependent on temperature. You would need to use a ohm meter to compare resistance vs temperature on a thermometer on your stove.
Im recalling thinking you ecm is bad, hot to the touch and the fans consistently running.
Going through the diagnostic trouble tree should have lead you to this conclusion.
our serial data line E at the aldl should be 2.5v or higher, if lower this indicates the ecm is faulty. This is the only test other than following other malf trouble trees to eliminate the function of all sensors/relays operation.
Old Sep 6, 2013 | 03:26 AM
  #67
saldav420's Avatar
Transmission: 700r
I tested both temp sensors the bigger one didn't work the smaller one worked fine, only thing is no auto store carries the actual sensor I need wich is the bigger one with more resistance. They have the smaller one with a choice of buying it with a pigtail connection. I don't know how to add a picture to show witch one I need. But I did see one here before. I will attempt to add photo here.
Size:  270.2 KB the one with the red arrow is the one I need and most likely causing my running rich problem. But no auto store carries it, would you know if there is somewhere I could order it from or could I use two of the same ones withe the blue arrow. The ECM they have it on stock if that's my next choice. I hope to god I'm getting closer to this issue pls continue to help me man!! I really do appreciate it all.
Old Sep 6, 2013 | 03:41 AM
  #68
Engine: Lb9
Transmission: M20
Gm/acdelco 12146312, 15326386
http://www.autozone.com/autozone/par...h&fromType=oem
Old Sep 6, 2013 | 03:42 AM
  #69
Engine: Lb9
Transmission: M20
In your picture the cts and cold start timer switch positions are swapped.
Old Sep 6, 2013 | 03:44 AM
  #70
Engine: Lb9
Transmission: M20
I'm really not thinking its your cts, your fans running constantly and the ecm being hot throw a red flag.
Old Sep 6, 2013 | 04:00 AM
  #71
saldav420's Avatar
Transmission: 700r
My fans run on a switch not constant, they have individual relays and fuse holders. I did noticed that one of the fuse holders was burnt but fuse wasn't poped. They are aftermarket fans and I connected them exactly how the intructions said except just with one switch, I think that's why the fuse holder got hot and melted but not poped.
Going back to the cts yes in this pic they are in oposite sides, but in my motor they were on correct sides. The red arrow one was tested with a ohms reader and showed no reading even after I put it in hot water. The other one in blue was tested with and without hot water and showed reading both times. The cts in my opinion could be the reason why after the car gets hot it stays cool and sends that message to th ecm. I may be wrong but at least I'm trying to figure this out, pls reply with what you think.
Old Sep 6, 2013 | 04:11 AM
  #72
Engine: Lb9
Transmission: M20
The one with the red arrow is the cold start timer switch.
When the ignition switch is turned to the crank position power is sent to the purple and white wire of the cold start timer switch and the ninth injector. The timer switch controls the ground side of the injector.
Old Sep 6, 2013 | 04:21 AM
  #73
saldav420's Avatar
Transmission: 700r
Not to sound like a retard but what does all this mean? The CTS on my car is no good. What am I suppose to do? Replace my ECM or my CTS. The CTS had no reading at all.
Old Sep 6, 2013 | 04:26 AM
  #74
saldav420's Avatar
Transmission: 700r
What you xplaining here is how to test the sensors? But I removed them fom th block and had them tested. And one failed. Your the expert here could you please explain it easier so I could undestand it better. Thanks!
  #75
Engine: Lb9
Transmission: M20
If this doesn't match This
replace it !
Old Sep 6, 2013 | 04:32 AM
  #76
Engine: Lb9
Transmission: M20
The one you said failed if the contacts are not closed below 95F this will result in the ninth injector not spraying fuel and a hard start will occur.
Old Sep 6, 2013 | 04:40 AM
  #77
saldav420's Avatar
Transmission: 700r
This is the one I need that failed, where could I get one. I also plan on deleting the ninth injector
Old Sep 6, 2013 | 04:46 AM
  #78
Engine: Lb9
Transmission: M20
The bosch 0280130229 is way over priced, placing a ad in the wanted classified section here maybe the way to go.
Bosch 0280130229 Thermostat Time Switch : Amazon.com : Automotive Bosch 0280130229 Thermostat Time Switch : Amazon.com : Automotive
Old Sep 6, 2013 | 07:20 AM
  #79
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If that cold start switch failed, the CSI (9th injector ) wouldn't be working at all unless the injector itself was leaking as I detailed above
So save your $$$ , why buy a expensive switch for something you are going to delete ?
Old Sep 6, 2013 | 11:16 AM
  #80
saldav420's Avatar
Transmission: 700r
So I f I were to delete the 9th injector what do I do with CSI switch, plug it? Leave it on but don't connect the connector to it. Or does the bypass kit come with whatever I need?
Old Sep 6, 2013 | 12:43 PM
  #81
Engine: Lb9
Transmission: M20
The csi block off kit just blocks the fuel supply to the 9th injector and plugs the runner port to prevent a vacuum leak. You should still have your computer memcal reprogramed to aid with cold start enrichment.
http://www.ebay.com/itm/Chevy-TPI-SBC-Cold-Start-9th-Injector-Block-Off-Delete-Kit-/310724821775?pt=Motors_Car_Truck_Parts_Accessories&hash=item4858a4830f&vxp=mtr
Old Sep 6, 2013 | 03:41 PM
  #82
saldav420's Avatar
Transmission: 700r
So would that solve my problem?
Old Sep 6, 2013 | 03:50 PM
  #83
saldav420's Avatar
Transmission: 700r
Chevy TPI SBC Cold Start 9th Injector Block Off Delete Kit | eBay
My computer would have to be reprogramed if I use the 9th injector block off delete kit? How much would than cost?
Old Sep 6, 2013 | 05:43 PM
  #84
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Maybe but at the moment you haven't done any actually testing to show / prove that CSI the cause of your rich condition.
As already stated ,
disconnect and plug the CSI fuel supply and see if you still have problems before wasting $$$ and time for nothing
Nothing
it fills the hole , that is all you need.
Old Sep 6, 2013 | 06:19 PM
  #85
saldav420's Avatar
Transmission: 700r
As already stated ,
Nothing
Well I know the CSI is no good cause I had it tested with the ohms reader and had no resistance by itself or in hot water. But ill put it back together and leave it disconected and see what happens
Old Sep 6, 2013 | 06:36 PM
  #86
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You are just not getting it are you ??????
You tested the cold start SWITCH which controls the 9th injector.
I have yet to see you say you have tested the cold start (9th ) INJECTOR how I explained above ;
the thing that actually sprays the fuel into the engine.
At this point in time ,forget the faulty CS switch even exists , it is not the cause of your problem .
If it really worries that much ,buy a 50c 1/2" NPT plug from a plumbing shop to fill the hole in the intake.
Solved
Then move on to finding the real problem
Old Sep 6, 2013 | 06:47 PM
  #87
saldav420's Avatar
Transmission: 700r
Ok sorry VETTEOZ I guess I got confused, could you please tell me again how to do the test for the ninth injector.
Old Sep 6, 2013 | 07:14 PM
  #88
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Post # 84 above.
You need to remove the supply line to the CSI from the rear of the fuel rail and cap off .
This will prevent any fuel getting to the CSI to see if that is the source of your rich problem
Old Sep 6, 2013 | 07:19 PM
  #89
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Alternatively you could undo the rail fitting , remove the CSI , reconnect the fitting and position the CSI outside the intake.
Then with plenty of rags under the CSI (carefully , no spark or smoking) turn on the fuel pump and see if any fuel comes out of the CSI.
If it is working correctly , you should have no fuel showing
Old Sep 6, 2013 | 07:23 PM
  #90
saldav420's Avatar
Transmission: 700r
I thought the red one was the CSI
Old Sep 6, 2013 | 07:24 PM
  #91
saldav420's Avatar
Transmission: 700r
Post # 84 above.
The csi is the one you circled in red?
Old Sep 6, 2013 | 08:26 PM
  #92
saldav420's Avatar
Transmission: 700r
Size:  143.3 KB ok I removed this and primed the fuel and no fuel came out. Did I do it right?
Old Sep 6, 2013 | 08:29 PM
  #93
saldav420's Avatar
Transmission: 700r
Size:  67.1 KBor do I remove it from the back?
Old Sep 6, 2013 | 08:45 PM
  #94
saldav420's Avatar
Transmission: 700r
So I just disconected the fuel line to the back of the fuel rail and yes gas came out. So what now
Old Sep 6, 2013 | 09:10 PM
  #95
saldav420's Avatar
Transmission: 700r
Old Sep 6, 2013 | 09:38 PM
  #96
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As you have been told ;
that is the COLD START SWITCH that operates the cold start INJECTOR we are discussing above.
Old Sep 6, 2013 | 09:40 PM
  #97
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Yes
Did I do it right?
Was it still connected to the fuel rail?
If so ,then a leaking cold start injector is not the cause of your rich condition problem .
Back to square one.
Old Sep 6, 2013 | 09:46 PM
  #98
saldav420's Avatar
Transmission: 700r
So I'm thinking the thermostat time switch is bad, since I tested it with ohms reader and got nothing. But idk please continue to help I trully appreciate it
Old Sep 6, 2013 | 10:51 PM
  #99
saldav420's Avatar
Transmission: 700r
Yes
Back to square one.
Ya it was still connected and no fuel came out, I disconnected it from the fuel rail and that's when gas did come out
Old Sep 6, 2013 | 11:42 PM
  #100
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
FORGET ABOUT THE CS SWITCH
It is not the cause of your problem.
If the wiring to that switch is disconnected it doesn't matters if it is working or not.
Is just sitting filling a hole in the intake
Move on
