IAC valve replacement
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Can I replace the IAC valve without removing the throttle body?
If so, what kind of tool would you recommend using?
I tried with a small monkey wrench but it didn't work...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IAC valve replacement
IIRC 1 1/4 open end wrench or j tool 35632 , the iac housing does not need to be removed.
But I don't think an open end wrench will fit, because there's not much space between the IAC valve and the throttle body.
Also, there's not enough space to use a long wrench there.
Ideally I should use j tool 35632, but isn't there any other good way?
Engine: Lb9
Transmission: M20
Than get a deep 1 1/4 or 32mm socket and grind the sides if needed for clearance between the tb.
Engine: Lb9
Transmission: M20
I use this one a little bit of a snug fit but works well
http://www.ebay.co.uk/itm/GM-KENT-MO...item2307c9ac1d
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
I would reccommend taking off the throttle body off anyway. Its really easy. It makes getting iac in a snap, and while its off you can clean out all the little nooks and crannys you cant reach while its on. Cleaning all that carbon buildup off the back of the throttle fins and out of the iac tube did wonders for my idle as well. i was wary of taking mine off, but im glad i did it. If you do it though, be careful with that detent cable for the tranny. I broke the clip on mine, and it was not easy finding a replacement.
mdtoren
Aug 16, 2015 05:45 PM
