Drilling blind oil passage hole
Old Aug 26, 2013 | 12:12 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Have a 1975 350 and am converting it to TPI. When I went to install the oil pressure sending unit, the hole above the oil filter is threaded but blind. I am assuming that is where the sending unit would thread into? Or is the it non drilled hole lower and to the left?
Can I just use a small bit and drill through into the passage? If not I will just get some fittings and run it off the hole behind the intake manifold.
Old Aug 26, 2013 | 05:58 PM
Re: Drilling blind oil passage hole
No that is not the oil pressure sender hole. That's the boss for the clutch Z-bar pivot ball.
I can't see enough of the block to be sure, but the undrilled spot may be where it goes. The bolt hole CERTAINLY is not, however.
Old Aug 26, 2013 | 06:27 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I went ahead and found an assortment of brass fittings to make the dash gauge sending unit/OPSU/mech. gauge work off the oil hole behind the intake. It is easier that way.
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
