valve adjustment issue
Old Aug 26, 2013 | 02:09 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
i put together a 350 and put new heads on it. i found on numerous sites an order to adjust the rockers. my issue is that when i go by what everyone says i have some lifters at what looks like full lift. i did it anyway and turn the engine over to #6 at tdc and some of the rockers i had just adjusted were completley loose. i went back to make sure i did it right and i did. so i adjusted the other set and tried to turn over and it wouldnt. i didnt force it i just backed them all off completley. anyone have the proper order of adjustment or possibly just the procedure? http://www.thedirtforum.com/chevyvalves.htm that is the order that i went in. any help would be much appreciated. thanks
Old Aug 26, 2013 | 02:25 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
Re: valve adjustment issue
the cam is a 12-242-2 comp cams
Old Aug 26, 2013 | 05:55 PM
Can't answer about "numerous forums"; unfortunately the Internet doesn't have any kind of "reality filter". especially not on forums.
But, however all that may be...
The easiest program to use, that's still pretty reliable, is the "EOIC" one. Exhaust opening, intake closing.
Turn the engine by hand, using something other than the damper bolt, until you see an exhaust just beginning to open. Stop, and adjust that cyl's intake at that point. DO NOT attempt to determine zero lash by "twisting" the push rod; instead, jiggle it UP AND DOWN, and slowly tighten the rocker until it JUST BARELY no longer has any UP AND DOWN play in it. Tighten the nut ½ turn more. Turn the crank exactly 90° and do whatever is the next cyl in the firing order the same way. (like, if it happened that you adjusted #8, do #4 next, then #3, etc.) Go through all 8 cyls that way.
Then turn the engine until you see an intake fully open and come almost all the way back closed. Just before it reaches full closed, adjust that cyl's exhaust, using the same discipline you used for the intakes. Once again, do all 8, 90° at a time.
I see you are in the S Chicago burbs... I lived around there for a time, long ago.
Old Aug 26, 2013 | 06:29 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There are plenty of satisfactory methods for adjusting valves. The elegance in the procedure described by sofakingdom above is that it is a foolproof procedure for any SBC with hydraulic lifters.
Old Aug 26, 2013 | 08:28 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Rockers getting loose after you have adjusted them is normal; they will tighten up again once the engine is running and the lifters have oil pressure.
NORTz89
May 20, 2020 03:51 PM
db057
Sep 4, 2015 07:57 AM
crazynights
Aug 21, 2015 06:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
