Kickdown Cable Question
Old Aug 26, 2013 | 06:27 PM
maxjivi05's Avatar
A year ago I had a friend swap engines and go from TBI to Carb, he did a lot of the work but stopped working on it and when I got digging into it I had to swap the bottom end out for another due to Mains being wore out... Well it's up and running and everything just about is tuned right except my Kickdown Cable.
I have hooked it up and adjusted it so it's fully pulled with the peddle all the way down but when going on the highway if I step on it, it won't down shift... I don't understand why it's not working, is there a better way to adjust it or is there something else I should be looking at to see if there is an issue there?
(((Could this be a computer issue, since it used to run off the computer and now it is just Carb))) I had to install a push button start so I could jump the starter to start due to the ignition switch being bad but security light stays on but I don't think that matters if it does I can get resistors and put in the line.
Old Aug 26, 2013 | 07:12 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Kickdown Cable Question
What carb?
You will need a geometry corrector.
Dont use the gas pedal to reset the TV cable.
After you install the geo. corrector, push in the " D " to unlock the cable HOUSING.
Push the HOUSING all the way to the firewall direction.
By hand manipulate the throttle to wide open-- the housing should ratchet out towards the front of the car.
Basicaly set.
Read the info at
www.tvmadeez
Tells how the TV cable works & what its responsible for.
Hope this helps
Old Aug 26, 2013 | 08:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by maxjivi05
Kickdown Cable.
It is not a "kickdown " cable like on earlier trans. It is the cable that controls all the shift points
if I step on it, it won't down shift... I don't understand why it's not working, ..... is there something else I should be looking at to see if there is an issue there?
Some light reading . Post # 24 in particular
https://www.thirdgen.org/forums/tran...-too-fast.html
Could this be a computer issue?
The only thing the computer controls on your trans is the convertor lockup ;
nothing to do with the gear shifts
Old Aug 27, 2013 | 06:16 AM
maxjivi05's Avatar
I have a Holly 600 Carb from AutoZone, and looking at that site I have the "stock" TV Cable... I'm going to try and figure it out after work and try to fix it. Thanks again.
just a question how do I know if my Gov is working properly or hooked up for the transmission if I get the TV Cable adjusted properly and it won't shift right?
----EDIT----
I went and adjusted it and .... now it won't shift to 3rd or 4th gear... It revs up all the way till I get 44MPH and shifts to 2nd but won't go to 3rd... I loosened it and it is doing the same thing.... and I took it off and it's still acting the same... Could I of knocked something loose that is causing it to think I'm still WOT when I'm only barely accelerating?
Old Aug 27, 2013 | 08:17 PM
Car: '87 Camaro
You **may** need the Holley throttle & TV cable bracket.
Jegs // Summit
You need a geometry corrector for Holley, also Jegs // Summit unless you have one.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
