Tapping noise?
Old Aug 30, 2013 | 11:18 PM
Jared N259's Avatar
Tapping noise?
So recently my car has recently developed a weird "tapping noise". Its relatively loud and keeps pace with the rpm level. as in, its regularly paced, and the spacing between taps decreases as the rpms increase.
Low RPM:
TAP.....TAP.....TAP.....TAP.....TAP.....TAP.....TAP.....TAP....
HIGH RPM:
TAPTAPTAPTAPTAPTAPTAPTAPTAPTAPTAPTAP
Eventually at around 3000 rpm it sounds like someone is firing a machine gun, in terms of rate, not in terms of volume. When under the hood, the sound seems to come from the rear drivers side of the engine. The exact location is difficult to determine though.
Anyone have any ideas of what might be causing this?
Old Aug 31, 2013 | 08:03 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Tapping noise?
First, tighten your exhaust manifolds if any bolts are loose i recommend replacing the gasket.
Pull one spark plug wire one at a time and listen for a change in the sound. If you pull one plug and the sound is reduced significantly the problem is in the bottom end on that cylinder. (WARNING: DO NOT PULL THE SPARK PLUG WIRES BY HAND! THERE IS A LOT OF VOLTAGE THERE AND A GOOD CHANCE YOU WILL GET SHOCKED! USE INSULATED PLIERS AND GLOVES!) It will not kill, you but it will hurt.... a lot.
Pull the valve covers and turn over the motor by hand make sure all valves are opening and closing equal amounts. You can also run the motor and watch the rocker arms for unusual behavior.
Inspect flex plate for cracks.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
dimented24x7
Sep 6, 2015 03:51 PM
