Car died and wont start.
Old Aug 29, 2013 | 04:27 PM
SmokinMyTires's Avatar
Car: 89 GTA, 89 Z-28, 96 Firebird
Engine: 5.0 TPI, 5.0 TBI, 3.8L
Transmission: stock 700-r4
Axle/Gears: stock
I was driving the other day and as i pulled into my parking spot smoke was coming from the hood. The hose on the heater diverter valve broke off and when i touched it to try and stop the leak, anti-freeze shot everywhere. Once that subsided I ordered a new one and just installed it today. Car started right up and all worked well. letting the car run for 5 minutes to check that the connections are not leaking, the car died out of nowhere. No change in rpm's, no smoke no nothing. car just straight up died. I tried restarting it and it would turn over well, but no starting. Fuel pump would prime just fine. I checked all my fuses and all are good. Pulled a spark plug and there was no spark. What is my next step to diagnosing and fixing this problem?
a few years ago the car had starting trouble and I needed to do the VATS bypass. if i remember correctly the car wouldnt turn over at all. Doing some research about VATS, if there is a problem with the system, the car will turn over but not start.
Any help?
Old Aug 31, 2013 | 08:07 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Car died and wont start.
VATS does not effect the ignition systems so I think your ok there. Is your coil remote or HEI? When you crank the motor does your tachometer get a reading?
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
