What kind of distributor cap is this?
Old Sep 1, 2013 | 07:15 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I picked up a GM HEI dist from a guy and he said it had MSD internals. There is no coil in the cap, just an empty cap and a coil wire mount. Am I correct in assuming he was running an external coil and probably some kind of ignition box for a tach since there are only 2 wires on the dist? I have attached some pics to give you guys a better idea of what I have. I wont be running an ignition box, so should I get a rebuild kit with an ignition module and a coil in cap?
Old Sep 1, 2013 | 07:20 PM
drdave88's Avatar
Engine: 6.0L
Re: What kind of distributor cap is this?
Sorry, they didnt post the first time.
http://s878.photobucket.com/user/drd...N0333.jpg.html
http://s878.photobucket.com/user/drd...N0334.jpg.html
http://s878.photobucket.com/user/drd...N0335.jpg.html
http://s878.photobucket.com/user/drd...N0336.jpg.html
Old Sep 1, 2013 | 07:36 PM
Damon's Avatar
Oh, yeah, that's clearly been converted over for use with an ignition amplifier box and an external coil. Notice there is no module or condenser inside the body any more- just the mag pickup. And the external tower on the "convert a cap" is where you attach the coil wire from than external coil.
It's pretty grungy inside. I would check to make sure both the centrifugal and vacuum advance mechanisms are working before you throw any money or time into it.
Old Sep 1, 2013 | 08:49 PM
drdave88's Avatar
Engine: 6.0L
I found a rebuild kit on summit with those parts for under $100.
Old Sep 2, 2013 | 09:10 AM
JaBoT's Avatar
an entire new hei distributor from summit is under $100 with coil and all.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
