Has anybody used these heads studs???
Old Sep 2, 2013 | 10:08 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys, I'm in the market for a set of head studs for my LT383. I've checked out the ARP head studs and 180 bucks right now is a bit steep for me at this moment. I've done a little research on this from procomp and I haven't found anything negative on them thus far. Here's the studs in question...
http://www.ebay.com/itm/HP-Head-Studs-sb-Chevy-283-305-327-350-383-400-190-000-PSI-ProComp-Cylinder-sbc-/200933452121?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec8912959&vxp=mtr
Has anyone here had any real experience with these? I know I'll hear "procomp sucks!!" but I've used some of their stuff in the past i.e. intake manifolds, water pumps.. and I haven't had any issue. If I can save a buck or two that would be great. any feedback would awesome.
Old Sep 3, 2013 | 08:52 PM
Re: Has anybody used these heads studs???
anybody?
Old Sep 4, 2013 | 12:58 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Pro Comp = Hecho en China
take that for what it's worth.
No sense to spend hard earned money on the entire engine and suffer a failure due to cheap fasteners.
that is what you call "stepping over dollars to save dimes"
Old Sep 4, 2013 | 08:53 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If these are of low quality AND you had a problem with them you may never know until it's too late. Being in the rocker valley area you will never see them unless the valve cover is off. So because of that I would passing on them depends on your habits. If you are willing to periodically recheck the torque then go for it, if not then pass. I also have had parts by them that were of fine quality but I could see them and easily replace them. Is there a reason that you can't use ARP bolts?
Old Sep 4, 2013 | 09:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
GM doesn't use ARP fasteners and I would presume that GM got there fasteners from outside the United States.
Old Sep 5, 2013 | 01:30 PM
FRMULA88's Avatar
Car: 1988 Formula
Perhaps but I guarantee they were made to GM specifications and tested per GM QC standards.
I am pretty sure GM just did not walk into a Home Depot in Mexico to get bolts for the LS engine in the "hardware aisle" The same goes for any other Car manufacturer, they are not using Ebay hardware.
The average consumer does not know about yield stresses, metallurgy, thread rolling, etc.. they just want "cheap stuff". Cheap does not equate to quality or the correct part for the intended application, which is why whatever product a car maker uses are made to their standards.
You cant compare Pro Junk or All crap to ARP or even GMs fasteners.. because there is no comparison.
italiano67
Dec 11, 2016 09:21 AM
Magman
Sep 12, 2015 10:43 PM
z28guy134
Sep 1, 2015 11:50 PM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Aug 25, 2015 12:54 AM
