91 Camaro not shifting out of first with pedal to the metal
Old Sep 5, 2013 | 07:47 AM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Transmission: auto/stock
Axle/Gears: stock
When I'm petal to the metal, it doesn't want to come out of first to second... it's as if you put the shifter in first and left it there but it WON'T go over whatever RPM it's expecting to shift from first to second (tac is not working). Now if I go 1/2 or 2/3rds on the petal, it shifts perfectly.. there is no slip what so ever.. engine is super tight..
Any ideas what might be causing this?
background of vehicle and other things to note
This is on a 1991 Camaro Z28 with an engine swap.. I don't know anything about what else was done to it but looks like there is a lot of new parts.. engine is ultra smooth on idle, doesn't miss a beat even when hammering on it..
Old Sep 5, 2013 | 08:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 91 Camaro not shifting out of first with pedal to the metal
Either the TV cable that controls the shifts is not set correctly or the governor in the trans is stuck.
Set the TV cable 1st and see what affect it has
https://www.thirdgen.org/forums/post...160-post3.html
https://www.thirdgen.org/forums/tran...-tv-cable.html
Originally Posted by vdoggie
a 1991 Camaro Z28 with an engine swap.. ..
doesn't tell us alot
You make no mention of what engine , carb or EFI .TBI or TPI .....?
Old Sep 5, 2013 | 09:15 AM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Axle/Gears: stock
I will definitely look into that.. I assume if it's the governor stuck the repair is going to be expensive if I don't do it myself?
Also, is there any clue as to why it shifts perfectly as long as I'm not full on the throttle? Does it point to one more than the other for a potential fix?
Thank you!
edit:
It's a 350 5.7litre and I would assume still TPI.. I don't see a carb on there.. I just got it so I really don't know many details.. sorry
Last edited by vdoggie; Sep 5, 2013 at 02:21 PM. Reason: update to answer questions
Old Sep 5, 2013 | 02:31 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
part throttle shifts = TV cable
WOT shifts = governor
I would get the tach fixed first, and then see how far it revs in 1st gear @ WOT before it shifts to 2nd.
It could be someone was playing with the governor to alter the shift points at WOT, don't be worried just see where it's at.
I did this to mine so I could drag race in "D" and not worry about shifting. I adjusted the governor to give me WOT shifts at 6000 RPM on my 383 setup.
The governor is easy to service / replace. the cap is on the drivers side of the trans.. its a round cap with a metal clip to hold the cap onto the trans case.. You mofidy the governor by replacing the springs and weights, pretty simple. B&M makes a kit for it.
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
