LS1 T-56 ls2 clutch question
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm planning on replacing my ls1 clutch with a factory ls2 setup, I already have a new LS1 pilot bearing, throwout bearing and slave cylinder. Can I use them with the LS2 clutch setup or do I need to replace them with LS2 specific parts?
Car: `86 SS / `87 SS
Re: LS1 T-56 ls2 clutch question
The pilot is fine; you're not changing the trans. or engine so it won't change. And the pilot is independent of the clutch as far as fitment.
You'd be fine w/ a sizable shim and the LS1 slave but... with it apart, you may as well get a new slave. And you need to verify if shimming is needed anyway.
