Stalling.. Help
Old Sep 6, 2013 | 02:22 PM
mchaggisbrewery's Avatar
Car: 92 Camaro Z28
Engine: 5.0
Transmission: auto
Stalling.. Help
92 Z28 305, car stalls at idle and when in gear. replaced plugs, cables, o2 sensor, distributor cap and button. pulled codes and they were across the board, some pointed to the ecm. changed the ecm no more codes generated but still stalls. I am also a novice so if anyone has any ideas please be descriptive.
Old Sep 9, 2013 | 12:09 AM
Guitarsmasher's Avatar
Car: 85 camaro
Engine: Carburated 305 V8, 2.4L 4banger
Re: Stalling.. Help
Try cleaning out the throttle body with throttle body cleaner. Just open it up and spray it in there. If your engine is carburated, clean the carburator with carburator cleaner the same way. Thats what i did when mine used to stall. Also check if its getting enough air. See if the filter is rlly dirty.
1Bad3rdGen
Alternative Port EFI Intakes
Aug 28, 2007 11:27 AM
breathment
Sep 29, 2002 03:56 PM
scoob8000
Jan 1, 2001 08:52 PM
