Button Bolt not available from GM
Old Sep 7, 2013 | 07:35 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
If working on your engine, be careful removing those button bolts around the plenum & manifold. They strip easily & GM no longer supplies replacements, but some rural dealers might still have a few.
The part number for bolts that connect plenum to manifold (the long ones that bolt in from the back) is 14081017 & they cost about $2.50. Nothing like them at Ace Hardware, which otherwise has an amazing number of automotive grade bolts & clips, cheap.
Old Sep 7, 2013 | 10:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Button Bolt not available from GM
If having to swap them most change the Torx bolts to cap screws (Allen key )
The Allen key doesn't strip the head out like a mis aligned Torx bit does , the bolts are more common and generally cheaper
Old Sep 8, 2013 | 03:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Bolts needed for top plenum and runners- 13- M8x1.25x30mm, 2- M8x1.25x40mm, 4- M8x1.25x50mm, 1- M8x1.25x30mm throttle bracket stud, 20 total,
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
luvofjah
Sep 3, 2015 07:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
