Camshaft bolt locking plate 4 step nose cam issue
Old Sep 11, 2013 | 07:15 PM
Pats91Z-28's Avatar
Car: 1991 chevrolet camaro Z-28
Engine: 385ci
Transmission: T56 6speed
Axle/Gears: 3.42 posi LS1 Disc brakes
Im wondering if there is a camshaft bolt locking plate for the later style roller cam with the step nose? The bolt pattern is smaller on the cam chain sprocket than the earlier style roller cams that dont have the step nose. If one is not available, im thinking of using lock washers with lock tight. Would that be good enough to keep them secured. Thanks
Old Sep 11, 2013 | 09:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Camshaft bolt locking plate 4 step nose cam issue
Didn't look that hard but never came across a flat for OE roller cams.
i just use Loctite on mine with no bad effects (yet)
Old Sep 12, 2013 | 04:25 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i've never used anything but bolt torque to hold those bolts in, and never had them come loose...
if it's good enough for GM, it's good enough for me..
Old Sep 12, 2013 | 06:57 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Not sure what you are refering to, but all the oe rollers were step nose. There are two styles of cam retainer plates, both for step nose but bolt spacing is different.
If its flat then its not an oe cam
Old Sep 12, 2013 | 02:42 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Not the retaining plate, the bolt locking plate.
Like this one:
http://www.jegs.com/i/Crane+Cams/271/99168-1/10002/-1
I ran into the same problem on the 383 build. Don't bother with lock washers, loctite will work fine.
Old Sep 12, 2013 | 02:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Oh, that makes sense.
You really dont need one. Touch of locktite and torque alone will be enough. Oem never used one. 166k miles on my l98, never loosened
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
camaro71633
Sep 1, 2015 10:24 AM
Jake_92RS
Aug 17, 2015 09:42 AM
mdtoren
Aug 16, 2015 05:45 PM
