speedo help plz
Old Sep 14, 2013 | 05:54 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
speedo help plz
well I have a 92 Camaro, so that's electric, and I swapped a mechanical t-5 in. I order this part http://tpiparts.net/inc/sdetail/7587 and hooked everything up, but the speedo still reads ~32mph (while car is not moving)and when moving (~30mph+) will jump to 60mph and kinda just dance between 30-60mph.
any ideas on why its doing this?
Old Sep 14, 2013 | 07:21 PM
Damon's Avatar
Re: speedo help plz
What do you have on the other end of that retrofit VSS? You don't have a mechanical speedometer cable to screw in there, obviously. Is there a "plug" they give you with it in case you don't need to drive a mechanical cable out the far side?
Cool looking part. Didn't know they existed. Just sucks it's not working for you. Scratching my head trying to figure out why it's not. Unless it's just bad outta the box.
Old Sep 14, 2013 | 07:36 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: speedo help plz
its got both actually. it screws onto the mechanical speedo and has a plug that plugs intot he exsisting plug, but can also run a mechanical cable at the same time. im ofc using the exsisting plug.
im thinking it might not be the part bc b4 I put it on the speedo was reading 30 all the time, instead of zero like it use to when I first swapped the trans. when the vss wasn't hooked up ofc it had the check engine light, but now its off.
Old Sep 15, 2013 | 01:36 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: speedo help plz
in the next few days im going to take the cluster off and see if that will somehow fix it.
the only other time ive seen a speedo do this was in my 03 Silverado when a $400 computer went bad... so is my computer going bad? (ofc I releize the obv differences)
Old Sep 20, 2013 | 01:16 PM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: speedo help plz
The VSS should be sending the same signal to the computer and the speedo, if your not getting a fault code from the ecm then there is a good chance the VSS is fine but the speedo is probably bad.
Old Sep 23, 2013 | 05:44 AM
DARKmj16's Avatar
Engine: 305 tbi
Re: speedo help plz
code 24 is being thrown. thinking buffer box, but the odometer still works.
Old Sep 23, 2013 | 09:02 AM
mcquigg's Avatar
Car: 85 T/A
Re: speedo help plz
You should be able to get the buffer off eBay pretty cheap, I keep an extra one around just for diagnostics.
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
