Engine Compression Ratio / Performance
Old Sep 15, 2013 | 06:28 PM
maxjivi05's Avatar
Engine Block Casting #10243880 = 1996 + 2 or 4 Bolt Vortec Roller Blocks
Head Casting #3890462 = 1966 - 1967 64cc "Has accessory holes" Flat Tappet Rocker Arms
Head Gasket #7733PT2 = Fel Pro 0.039" Compressed Thickness
Roller Camshaft & Lifters
The heads were warped when I bought them and had to have them shaved to square them off, I don't remember the exact amount removed but he said he had to remove a good bit.
From my calculations that would put the car without heads shaved around 9.94:1 Compression Ratio but with heads shaved a tad more around 10:1.
The Camshaft I have is ... hard to make out the actual part # to find out the lift etc from it, not sure if any of you can help identify it, but I'd like to know what kind of Horsepower this engine is going to be pushing... I had issues where I broke my Camshaft Thrust Lock Plate and waiting on a new one so I'm running numbers and trying to figure it all out.
Attached Thumbnails Engine Compression Ratio / Performance-imag0494.jpg
Old Sep 18, 2013 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not sure how to find out more about that camshaft. The "2035" sounds like a Crane cam, but doesn't match anything that they actually sell (that I can find).
That said, using an unknown cam doesn't make any sense. Buying a new cam that you know will work with your combo is money well spent.
Sorry to hear you spent good money on those heads. I don't know where you got your information, but here's what the sticky in the Engine Swap forum says about them:
"3890462....66-67...302/327/350..Camel hump, no accessory holes, 64cc chamber"
Do they have accessory holes? I haven't seen any SBC heads before '68 that did. A set of Vortecs would run circles around them (with valve spring upgrade, of course).
You left out a few things about your CR, like deck height and valve relief/piston crown volume.
Old Sep 30, 2013 | 12:51 PM
maxjivi05's Avatar
Re: Engine Compression Ratio / Performance
I don't know the deck height but it's a stock block, stock flat top pistons with the 4 valve reliefs, and just say it was a "stock cam" even though it's a roller performance cam but I want to know bottle line horsepower/torque it should put out. I'm trying to save up and get new Vortec heads and intake but that will take time and $ then add roller rockers once I get a new roller cam.
Also the heads didn't have the holes originally, the driver head has a couple tapped bolt holes so you can still use a power steering for V-Bolt style that also bolts onto the exhaust manifold passenger side has no bolt holes for accessories the alternator is connected to a bracket that goes from the water pump to the intake manifold.
Old Sep 30, 2013 | 08:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by maxjivi05
even though it's a roller performance cam.
Being a roller cam doesn't make it a "pref" cam.
The L31 Vortec block you are using came stock with a low perf truck cam
191 /196 duration .414 /.428 lift
The "HiPo" version rated at 330Hp had
212 / 222 .435 /.460 . as you can see more valve lift and more duration
The popular ZZ4 performance roller cam has
208 / 221 .475 / .510
Old Sep 30, 2013 | 10:47 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
461s are smalll valve heads. not great performers til you put larger valves and some "work" to them. Will they run and bolt on yes. With those heads youre probably just under 10:1 which is safe. Power estimate impossible at this point.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
