Procomp heads
Old Sep 29, 2013 | 08:40 PM
Gomanjo283's Avatar
Procomp heads
Im considering a set of Procomp heads #3003 for an upcoming 383 build.
Im looking at a set cnc'd to 68cc chambers. Does anyone have these heads?
The flow #s look good for the price from Skip White. A question i have is are
Rocker stud holes 7/16-14 as typical on most after market heads? Thanks
Old Sep 30, 2013 | 02:38 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Procomp heads
They're really not good cylinder heads. The flow numbers are only a small portion to cylinder head technology, and the flow numbers are flat out BAD on procomp heads.
They're cheap for a reason. If you're on a shoestring budget go buy someone else's used heads and get something good for the money spent.
Old Sep 30, 2013 | 07:45 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Procomp heads
It appears the ProComp heads are Chinese copies of the Edelbrock heads.
I've been thinking of getting a set of complete ProComp heads from Skip White, which appear to be a pretty good setup.
Old Sep 30, 2013 | 09:21 AM
JaBoT's Avatar
Re: Procomp heads
I have used pro comps before and they are not good! To start with I don't believe those flow numbers for a second. And if you do believe them look at how low the exhaust flow is compared to any other head with the same intake flow. They are just junk. They have to use big crazy cams to make any power.
Save up a few more dollars and get a set of profilers. They are around $1050 shipped.
195 cc's if you going to 6500 rpm or 210 if your going to 7000 rpm
http://www.profilerperformance.com/r.../sbc-23-degree
Old Sep 30, 2013 | 09:42 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Procomp heads
The flow #s look good for the price from Skip White.Thanks
Their flow numbers are garbage. Their 210cc intake heads flow worse than many good 180cc heads.
Old Sep 30, 2013 | 01:24 PM
Gomanjo283's Avatar
Re: Procomp heads
Thanks Guys.....im taking your advice...it was between SHP200, Brodix IK200,and Pro Filer 176 series 195's.......the Pro Filers won out with a little better numbers and i believe better velosity..... $1138 to my door set up for a hdy roller.
Thanks again
Gomanjo283
Old Sep 30, 2013 | 01:29 PM
midias's Avatar
Re: Procomp heads
I would stop thinking about it unless you want to make crap for power.
Old Sep 30, 2013 | 09:27 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Procomp heads
Hey Pete - know anything about these guys?
http://www.ebay.com.au/itm/161004456...84.m1423.l2649
AFD, down your way. New local design sbc heads apparently.
Old Sep 30, 2013 | 09:51 PM
midias's Avatar
Re: Procomp heads
The only flow spec they have is at 650 lift. That is a worthless number
Old Sep 30, 2013 | 10:43 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Procomp heads
Could be a decent new head could be junk
As said peak # doesnt mean anything most just use it to sell heads as everyone foams at the mouth over peak # and just dont know any better.
Might try posting about those heads on speedtalk guarantee someone there has had thier hands on a set.
Old Oct 1, 2013 | 03:15 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Procomp heads
Yeah, I had a bit of a poke around a couple of local (Australian) forums several months ago, from what limited anecdotes I found, they get an ok rap from the Ford guys, at least for racing. They've only moved to an sbc offering recently afaik, and as noted above there's scant info on that ebay listing, or on their site.
Price is much better for us over here tho, for any decent aftermaket set from any mfg (ie anything better than Procomp) you're looking at $2k - $4k a set.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
