Oiling problem to rockers, as in nonexistent.
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
L03, all new bearing. Clearances checked and cam bearings oriented properly. No internal gallery plugs removed. Just 3 in front and 3 in back. oil pressure is like 30ish at idle. New lifters. Pushrod oil passages clear. No oil to rockers. When priming with valve covers off I can see oil flowing quite rapidly from the front of lifter valley to back and hear it draining back to pan.
Need opinions. What do ya think? Whats goin on here?
Re: Oiling problem to rockers, as in nonexistent.
Sounds like you're wasting your time "priming" the motor.
Wasting it even more than you would if you had a distributor body, or one of those tools that simulates one, to complete the right bank lifter passage, so the engine has about a 3/8" diameter HOLE aka LEAK from the pressurized system.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You need a special priming tool that has a seal at the lifter valley floor. Dont bother. Just move on with your build. If you really want to "prime" it, as long as you dont have a flat tappet cam, (you shouldnt!) just remove all teh spark plugs and turn it over with the starter for a few seconds. Should be all you need and no real load was put on anything since it didn't build compression. (Note remove ignition power also so that you dont stress the ignition system too hard while doing this)
You can do this with a flat tappet too, but with those it's super critical to get the thing moving at 2000-3000 RPM as soon as possible. You dont want to be wasting any more time just turning the engine over than you have to.
Axle/Gears: none
Source of issue found. Front plugs behind cam gear. Thanks for suggestions.
Axle/Gears: none
Getting oil up top now... curious on 2 things. 1... can oil sender register pressure to stock gauge without battery power to it? 2... is too high a pressure bad?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
- The stock gauge will not register pressure without electrical power to it. You can use a mechanical gauge instead.
- I don't think high pressure is bad, but it might not be desireable. I don't know where the threshold of "too much pressure is bad" is.
Axle/Gears: none
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
