Extremely high oil pressure?
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
Hey guys, I have an 89 Formula and I have a 5.7 Liter from a 1999 Suburban with a carburetor, and I recently drove it and the oil pressure became extremely high (over 60), and the service engine light came on. Does anyone know what the probable cause is? I'm hoping it's nothing serious like a spun rod bearing or a plugged oil pump...
Re: Extremely high oil pressure?
The Check Engine light is not related to oil pressure in any way. The old computer in these cars doesn't even have an input for it, therefore is completely unaware of it.
The reason the gauge suddenly read high is most likely because the wire came off the sending unit.
See my signature for a mental technique you may find helpful.
Transmission: 4L80E/4L80E
The SES light came on because you have a carb in an EFI car. The computer isn't getting the signals it thinks it needs, so it turns on the light.
Assuming it actually is a carburetor, and not a TBI unit.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
With no computer, you shouldn't be throwing any codes.
ambainb
Apr 25, 2016 09:21 PM
