Need engine identification
Not sure if this is where i should post this. Mods move if you need to. Anyway i picked up a 91 Camaro and i do not believe it has the original motor in it. The i.d. off the block on the passenger side below the head are as follows.
V0604CLD
1ML130188
I am trying to see if this is a 305 or 350 without having to tear into the motor. I can not find info at all using the i.d. Any help would be appreciated.
V0604CLD
1ML130188
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need engine identification
Engine code CLD shows up as a 73 or 77 350
Read
https://www.thirdgen.org/forums/tech...ification.html
Only the block casting number at the rear would better identify the block vintage
Read
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The thing that gets me though is the M in the VIN. M is not a 1973 or 1977 engine year code. M = 1991 which is what your car is.
Doing another search, I have found another CLD listing.
1991 305 found in third gens. L-03 TBI engine with a 700R4.
Does the 1ML130188 match the last numbers on the car's VIN? If so then it's the original engine. Sounds like you have an original 305 in the car.
The plant code in that VIN snippet is "L"; Van Nuys.
The only cars AFAIK that were produced there, were F bodies.
As Alky says, if the last 6 of that VIN (which is in fact a typical Camaro VIN) match your car, it's its original motor.
Don't be fooled by the "runs too good to be a 305" BS line.
84z96L31vortec
Aug 20, 2017 12:16 AM
