1986 camaro fuel pump cam ring
Old Sep 28, 2013 | 11:15 PM
Bigspoondude's Avatar
Car: 1986 Camaro
Engine: 5.7L LT1
So I am trying to troubleshoot a no fuel situation and can't figure out how to get the damn fuel pump tensioner ring off. Read in the shop manual that you can use the Kent Moore J-24187 wrench or a piece of wood and a hammer. Well since I am not a GM tech I grabbed a hammer and wood. All I seem to be doing is bending the verticle square piece.
Any tips or suggestions?
Posted from Thirdgen.org App for Android
Old Sep 29, 2013 | 07:50 AM
ex-x-fire's Avatar
Re: 1986 camaro fuel pump cam ring
Soak the top of the fuel sending unit/pump assembly in penetrating oil. I use a dull screwdriver & hit each one a couple of times then go on to the next one.
If its really rusty, I'll break the old one with side cutters & get a new one.
Old Oct 1, 2013 | 06:20 PM
Car: 1986 Camaro
Engine: 5.7L LT1
So I figured out what I was doing wrong. I was hitting the outer ring instead of the inner ring.
Still have no fuel issue and the car has a Walbro 255 in-line and the tank end has a strainer where the pump use to be. I assume I don't need one if a mechanical one can do it but open to advice.
Old Oct 1, 2013 | 06:22 PM
Car: 1986 Camaro
Engine: 5.7L LT1
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
