Dyno Results -- what causes the lines to be all squiggley?
Old Sep 29, 2013 | 08:43 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Went to a dyno day here in Utah with the local car club today. I hadn't had the car dyno'd since I had the original factory carb tuned for it. Back then (2009) I pulled a 238 to the wheels.
I sent the carb off to be built by Cliff Ruggles for my 350 and then had Autopontiac in London tune it when I was in England. Needless to say, other than extra mileage and the tune of the carb, it's basically the same motor.
Today I pulled 261hp and 292 torque. Not to shabby! Now, why are the lines all squiggley? Some of the cars were remarkably smooth..others weren't but mine is by far the worst of the ones I saw today. What does it mean? Any of you guru's out there have some insight to this?
Attached Thumbnails Dyno Results -- what causes the lines to be all squiggley?-dyno-day-sep-2013
Old Sep 30, 2013 | 09:00 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Dyno Results -- what causes the lines to be all squiggley?
That's not so unusual for a display with Smoothing = 0.
Replot it with Smoothing = 5, which is more typical to see.
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
Doobie52
Sep 11, 2015 06:19 PM
TBRays98
Sep 6, 2015 05:05 PM
