SBC balancer timing mark variations
Old Oct 3, 2013 | 03:54 PM
Drac0nic's Avatar
OK, I am curious if I am chasing gremlins here, my timing seems higher to me than I think it should be for the engine to be running well. Since I've got an L03 short block, not 100% on the timing cover and balancer. I'm wanting to ask you folks for some pics of this if you have them. Based on what I've read, there's 3 different positions for the pointer to be at on an SBC, one at the top then the others in the vicinity of 1:30 and 2:00 if I remember correctly. Anyone got pics of the balancers that show timing marks compared to the key ways?
Old Oct 3, 2013 | 04:30 PM
Twin_Turbo's Avatar
Re: SBC balancer timing mark variations
There's the 12 o clock position and the 2 o clock or thereabouts, the difference in the latter is that early balancers have the degree mark at about 2 deg. before the keyway and later ones 10 deg. The aftermarket chrome pointers all seem to be for a 10 deg. setup and will give probs if running with a pre 69 balancer. Best way is to get a top dead center stop and determine actual TDC that way.
Old Oct 3, 2013 | 05:46 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If the timing cover doesn't have the timing pointer at the 12 o'clock position it is not stock. If you want to bypass all the investigative work, buy a slip on balancer cover(6 3/4) that will set it up for a two o'clock timing mark and buy a timing pointer that bolts the timing cover. You can buy both for less than twenty dollars. Timing would then only be off if the inner and outer parts of the balancer had started to slip. That usually doesn't occer for many many miles, really high heat exposure or really high rpm.
Old Oct 4, 2013 | 03:48 AM
Drac0nic's Avatar
There are actually 3, I found out that I have a 40 degree balancer and a 20 degree. My timing is about 20 degrees retarded, Gonna be interesting readjusting my tune....
midge54
Dec 27, 2019 04:14 PM
InfinityShade
Aug 22, 2015 08:00 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
