Strange squeak from rear end after burnout (Video attached)
Old Oct 12, 2013 | 05:06 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Today I decided to do a little brake stand just having fun in the GTA. Almost immediately after leaving the empty lot and making a turn I hear a weird squeak from the rear end. Never heard this before. Doesn't do it in a straight line, really only when making a U-turn turning the wheel all the way. It'll do it turning left or right. I got under and looked but found nothing of the obvious. The rear isn't grabbing or slipping, no other sounds except for the squeak and it's not constant. The video will tell all. What do you guys think this could be? Any help would be greatly appreciated.
Old Oct 12, 2013 | 05:35 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Strange squeak from rear end after burnout (Video attached)
posi is hurt... possibly damaged the spider gears.
Old Oct 12, 2013 | 07:25 PM
Damon's Avatar
Rear brake pads worn down to the squeal bar?
Old Oct 12, 2013 | 07:29 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
If you don't have a line lock you probably glazed the pads and rotors bad. Then when you turn you're loading the tire causing the pads to rock and making that noise. There's probably a rust ridge on the outside of the rotor that's causing the issue.
Old Oct 12, 2013 | 07:35 PM
Just did the rear pads not too long ago but they were the cheapest auto zone ones.
Haven't pulled the tires yet so I'm not putting anything past it.
Jonesy, I forgot for that moment that I had 4-wheel disc brakes and it could have messed something up. Definitely don't have a line lock. You make a good point, but wouldn't it make that noise all the time? Or like you said only when a load is applied?
Old Oct 13, 2013 | 10:44 AM
Well drove the car last night and this morning and got everything up to temps and some, and the noise is completely gone. Tried to replicated it last night for my fiance and it wouldn't do it. I'm not complaining. But it wasn't for nothing
Old Oct 14, 2013 | 05:39 PM
Jonesyfxr's Avatar
I've heard brakes do funny things at funny times. Never know what'll happen.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
3rdgenparts
Aug 6, 2015 09:03 AM
