3.1 V6 cant hold idle
Old Oct 12, 2013 | 04:55 PM
VictorGBKirk's Avatar
Car: 91 Z28
Whats up guys, my 91 3.1L V6 91 RS cant and will not hold an idle. When you go to start it up you gotta give it gas or else it will just crank and crank. Once it starts tho it runs really rough and if you let off on the gas it just stalls out. I just had a new fuel pump in it less than a month ago. So anything helps at this point. Thanks guys!!
Old Oct 13, 2013 | 11:20 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 3.1 V6 cant hold idle
Check the fuel filter, pressure, regulator and injectors. Remove the idle air valve assembly and make sure all the passages are clean. Make sure the EGR isn't stuck open. Then.....
Old Oct 13, 2013 | 12:17 PM
Car: 91 Z28
Okay, i found this line and i have no idea where it goes. Its connected to the EVAP camister purge valve. Any ideas?
Old Oct 13, 2013 | 05:38 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
There are a couple of rubber lines that connect to hard lines that go back to the fuel tank. There is also a vac line that winds up under the plenum to the vacuum block on top of the throttle body.
Old Oct 15, 2013 | 06:49 AM
Car: 91 Z28
The car is just turning over now, i havent had the time to mess with it. Thanks for the help guys!
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
drt-rcr
Aug 27, 2001 06:57 AM
Red91Bird
May 17, 2001 03:51 PM
Sincat_23
Feb 10, 2001 11:23 PM
