please help!! crank no start!!
Old Oct 13, 2013 | 05:47 PM
drdpr72's Avatar
Car: 89 iroc
Engine: 383 tpi
Transmission: t5
Axle/Gears: 327 9bolt
cant seem to fire off engine I have spark I have 45 psi to rail and I have injector pulse with a noid light but it is not real bright I check both banks with noid check injector by making a jumper and tapped wires with power and ground with gage on rail it does drop slightly each injector added extra ground strap from engine to chassis replace pcm have two new distributors even tried putting new pick up and module to be safe still same results pulled plug and its dry as a bone fires with a can nut will not stay running have all new seals in rail adjust regulator injectors are accel 24# had them in one engine new ran a few times let sit on car due to spun bearing installed on new engine and unsure what to do or test next any ideas?
Old Oct 14, 2013 | 06:19 AM
ex-x-fire's Avatar
Re: please help!! crank no start!!
Check your coolant temp sensor, it could be reading hot when the engine is cold.
Some people skip posts that are hard to read, it helps if you use periods & paragraphs.
Old Oct 14, 2013 | 06:30 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by drdpr72
any ideas?
https://www.thirdgen.org/forums/tech...s-dumbies.html
Old Oct 14, 2013 | 11:33 AM
drdpr72's Avatar
Car: 89 iroc
Engine: 383 tpi
Transmission: t5
ok ty for advise
coolant temp sensor is new and no codes
first time tring to start new engine
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Tonyy_z
Aug 12, 2015 07:20 AM
