Fan constantly running after letting engine idle?
Old Oct 14, 2013 | 03:11 AM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I've had my car sitting for quite some time due to an interior overhaul and prep for paint work, so today I decided I would let my car idle for a while just to keep everything fresh. About 10 minutes later I shut off my engine and turn the key onto accessory and the secondary fan starts up and keeps running until I turn the ignition off. Anyone know what could be the culprit?
Old Oct 14, 2013 | 03:57 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Fan constantly running after letting engine idle?
AFAIK, that's normal. The water stops circulating when you turn off the engine, therefore the heat gets transferred into stationary coolant which sticks around the sensor in the head, resulting in your fan starting due to a temperature your gauge does not display.
Old Oct 14, 2013 | 02:57 PM
Axle/Gears: 3.45
That does sound completely logical, except I went to try it out this morning and turned the key to accessory (without turning on the engine prior to yesterday) the fan still started right up
Old Oct 14, 2013 | 04:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Firechicken86
turned the key to accessory the fan still started right up
Doesn't it have it's own fan switch in the head?
Maybe it is faulty?
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
