surging from bad gas?
Old Oct 19, 2013 | 07:56 PM
jmpowie's Avatar
Car: 91 canaro rs
Engine: 5.0
Transmission: 5 speed
I have read a ton of posts about camaros that have sat for a few years then started right up but after a few miles they got the "surging" mine is one of them. It seems that there is no one answer of how to fix the problem. Some change the map,ega,tbi or fuel pump. If the car ran fine before sitting why would it not after. It got me thinking is it the old gas? You mix 5gal of old gas with 10gal of new would it surge until all the old gas is gone? replacing the fuel pump would empty the old gas or running the car trying new parts like maps or o2 run the old gas out. Then the car works fine and you say it must have been the last thing that was changed. Is it that simple?
Old Oct 19, 2013 | 08:37 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: surging from bad gas?
Fresh gas should do it,I would do that 1st,then if the problem persist,it could be something else.
Old Oct 19, 2013 | 09:32 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
If the problem persist it's probably the idle air control sensor.
Old Oct 21, 2013 | 06:32 PM
vdoggie's Avatar
Car: 1991 Z28
Engine: 350 tpi
Transmission: auto/stock
Axle/Gears: stock
can't a dirty or clogged fuel filter also cause these symptoms?
Old Oct 21, 2013 | 07:29 PM
jmpowie's Avatar
Car: 91 canaro rs
Engine: 5.0
Yes it could, but it was a rhetorical question.
mike_c
Aug 27, 2015 04:32 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
