87 iroc no spark
Old Oct 24, 2013 | 12:17 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
87 iroc no spark
So 87 350 TPI.
Yesterday replaced the ICM because code 36. My code 36 is has historically been set by my ICM, why I dunno. My burn off circuit works done very thorough testing on it. Anyway.
Replaced the ICM and Rotor. Unplugged the computer to clear the codes. She fired right up. Let her idle a bit as whenever I reset my computer she misfires like a beast for a while. No idea why on she does though.
Get in to give her a test drive, get about 1000 feet from the house and she dies.
Now no spark. Plenty of fuel and air. Get out distributor cap is loose, bolt holes got stripped.
Get the cap bolted firmly today and still no spark.
The other thing that lead me to replace the module is when I put her in reverse she would surge and in general the exhaust tone did not sound right. I think that though is the IAC valve, it is making unusual noises, have a new one atm to install. Have a penny cracking open the throttle in the meantime.
My coil is new, replaced it with an MSD because it was 20 less the a BWD part.
The only thing I can figure is the new module burned out. Not sure why or how.
Gonna swap it out again tomorrow.
Any ideas in the mean time, I am afraid to play with the cap more than I have to. ICM and coil wires are intact and tight. Timing wire is tight as well.
EDIT:
Just went to play with it a bit. If I pull up on the rotor button and set it back down(like picking up a pen and and dropping it) the fuel pump primes again. Every time I do this results in a new prime cycle. Why is this? Is the pickup coil shorted?
Old Oct 24, 2013 | 06:10 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 87 iroc no spark
Back to basics , test everything
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Oct 24, 2013 | 05:26 PM
Engine: 383 HSR EBL
The ICM was dead dead. Found my old one and it fired right up, old one is going out but worked enough for the test.
Red iroc-z 305
Sep 30, 2015 05:22 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
mustangman65_79
Aug 11, 2015 03:17 PM
