Power Steering - fails over 400hp?
Old Oct 28, 2013 | 04:03 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Nothing much turns up in a search on this.
The FSM and other places mentions not to run the factory pump on over 400HP engines.
Anyone had any experience with what happens?
Anyone doing anything to reinforce? I see my pulley is pressed on only. Maybe a Locktighted bolt in there?
Thx.
Old Oct 28, 2013 | 04:23 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Power Steering - fails over 400hp?
Would this be an R.P.M. issue instead of a H.P. issue?
Old Oct 28, 2013 | 05:06 PM
TallTim's Avatar
Hmmm can't seem to find it in the FSM, will have to look again. Pretty sure it was not RPM related though. No idea where 400HP came from either.
Old Oct 28, 2013 | 05:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
1989 pump here. 6500 rpm and over 800 hp no issues here.
Same pump been through 7000 rpm on 600-650 hp nitrous 383
I dont see what hp has to do with anything. Rpm makes more sense but havent heard any limitations on pump speeds. Same goes for any accessory, water pump or alternator
Old Nov 1, 2013 | 11:03 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
HP has nothing to do with it.
And,.....on a daily driver or drag car, rpm won't matter either, as long as we're talking below 7000 or so.
For extended high rpm as in roadracing, yes, rpm is a concern with stock pumps. I don't know how bad it affects pump durability, but running 6000 rpm with a stock pump with stock pulleys for 5 or 10 minutes will boil the PS fluid.
Old Nov 2, 2013 | 07:22 AM
Edwardgp's Avatar
Engine: 454-350
Well at least we have an answer and this makes more sense. Thanks LG.
Old Nov 2, 2013 | 02:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Nothing a proper power steering cooler couldn't fix.
Road racing is causing constant hydraulic pressure from the continual turning. Pressure creates heat and you need some sort of cooler.
Drag racing and normal daily driving creates very little heat in the power steering fluid even if you were spinning the engine to 7000 rpm. Turning the steering very little only needs minimal pressure in the power steering system.
HP has nothing to do with power steering. Controlling the heat in the oil for how you intend to use the car is more of a concern. Any sort of aggressive driving such as road racing, autocross, offroading etc where you're constantly generating heat in the hydraulics simply needs a cooler to survive.
Old Nov 3, 2013 | 07:40 AM
86LG4Bird's Avatar
Alky, you quoted me out of context slightly there, didn't ya?
We're on the same page.
However, stock pumps DO churn and heat the fluid unnecessarily at high rpms, even with no steering input.
Yes, in my case I run underdrvien pulleys AND a PS cooler to keep things under control on the road course.
Anyway, I think we all agree on the response to the OP: disregard that "400 hp limit" for a daily driver, street bruiser, or dragrace application.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
