Fuel pressure at 40. but 10 when hot.
Old Nov 1, 2013 | 08:24 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
1991 v6 3.1. New Injectors, Fuel pump (bosch replacement). The Car sometimes has a extended crank in the morning, and when hot sometimes it will have a very high idle, 3-4K and slowly come down and starting running on 2-3 cyl's just about to die and sometimes does....
I just checked the Fuel pressure tonite. KOER Its at 43ish PSI and when i rev it, the pressure goes up smooth and gradually to 55 PSI and when i unplug the Fuel Pres. reg. it jumps straight to 55.... After sitting 25-30 Minutes KOEO the pressure rapidly bounces from 5-20psi and settles to about 10. Then we attempt a start, we get an immediate stall, and then a restart and the idle is high and then settles with the about to stall idle with the pressure at and in between 20-55 psi then the pressure slowly calms down to 43ish psi and idles wonderful. Ive got some research to do..... I just wanted to know if anyone has seen this and could pin point the issue.
Old Nov 1, 2013 | 08:44 PM
ex-x-fire's Avatar
Re: Fuel pressure at 40. but 10 when hot.
Pull the vacuum hose to the regulator & then watch the regulator port for fuel to come out, it might take a few minutes.
Attached Thumbnails Fuel pressure at 40. but 10 when hot.-0900c15280098fdd.gif
Old Nov 1, 2013 | 08:56 PM
Car: 1991 Camaro RS
Yea ive done that, and Nothing makes it out..... Ive done it while its running, and after i shut it off I never seen gas. left it unhooked for about 10 minutes..... I watched a video in youtube about it taking over 5 minutes for them to show a Liquid leak.... But other than that, i forgot to add, as soon as the engine is off/key off. the Fuel pressure drops to 0psi. Im not sure if these systems are suppose to drop that quick or not.
Old Nov 2, 2013 | 09:11 AM
ex-x-fire's Avatar
Time to pinch off the return right after the fuel rail, reprime, & watch for pressure to drop. It could be a leak inside the tank, the hose that connects the pump to the fuel line.
Old Nov 2, 2013 | 05:38 PM
Car: 1991 Camaro RS
Oh yuck...... These should hold pressure when the pump primes and shuts off right? hmmm. I guess I'll check that tmrw.... yay Thanks for the input.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
