1992 camaro 305 overheating/oil pressure drop.
Old Nov 4, 2013 | 09:03 PM
duke726's Avatar
My 1992 camaro is overheating. I can drive about 5 miles, then my camaro will begin to overheat. Temp rises above 260. Soon after the oil pressure will drop below 10. If no gas is given the oil pressure drops to zero, and the engine begins knocking. When I look at the motor at this point, it seems to be smoking from underneath the block. If it gets too hot, I can hear the coolant reservoir boiling. I have checked for moisture under the oil cap, and water on the dipstick, there is none. If I run it too long the engine smokes horribly, and shuts itself off. Engine is a 305 tbi. Please help!!
Old Nov 4, 2013 | 09:34 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: 1992 camaro 305 overheating/oil pressure drop.
Is the wind dam under the car ? - forces air over the radiator when moving ............... electric fan working ? Should kick on around 227...
Is the smoke white ?
Old Nov 5, 2013 | 05:28 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
I had this problem, at exactly 5.5 miles. Turned out to be a stuck thermostat, which caused a boil over, which caused need to replace head gasket. You may be at that point already.
Old Nov 5, 2013 | 05:51 PM
Car: 90 Iroc Vert
Engine: 5.0L
White smoke is bad - usually a sign of antifreeze hitting the exhaust. Not good.
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
