sensor in radiator??
Old Nov 7, 2013 | 07:02 PM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
a couple days ago i noticed a swimming pool under my car. poped the hood and alot of water is leaking out of a one wire plug in my radiator, not sure what it is. i cant find it on the net. can i replace just that what i belive is a sensor or does the entire radiator need to be changed
Old Nov 7, 2013 | 07:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: sensor in radiator??
a c4 coolant low sensor will plug the hole. gm Part 10054615
Amazon.com: ACDelco 10054615 Low Engine Coolant Indicator Sensor: Automotive Amazon.com: ACDelco 10054615 Low Engine Coolant Indicator Sensor: Automotive
Old Nov 8, 2013 | 10:07 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
The OEM radiator bowls are plastic, is the sensor leaking or is the threaded port cracked..
if the port is cracked you need to replace the radiator..
Old Aug 3, 2017 | 04:48 PM
Irocsters's Avatar
I ordered it up. Thanks guys!
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
romcjr
Sep 17, 2015 05:18 PM
