Engine taps after replacing intake gaskets
Old Nov 28, 2013 | 10:48 AM
  #51
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Re: Engine taps after replacing intake gaskets
Ohh coolant sensor
Old Nov 28, 2013 | 10:49 AM
  #52
Yea, I've been throwing darts at a dart board replacing parts
Old Nov 28, 2013 | 11:09 AM
  #53
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Focus on problems related to work that was recently done. Don't start swapping out miscellaneous parts and making other changes. You'll just wind up farther down that road of running like crap and not be able to find your way back.
Your CTS didn't just 'go bad' unless you f'd up the wiring somehow. FWIW you can always short the wiring leads to confuse the ECM into thinking the motor's full hot without buying a new CTS.
Old Nov 28, 2013 | 01:41 PM
  #54
Gotcha
Old Nov 29, 2013 | 10:57 AM
  #55
Ok. So I had a bad ignition module, and iac. The ignition module wasn't allowing the car to prime fuel at start-up. Then after I got the car to run the iac took a dump on me. So I got a new iac. Runs fine. But a slight miss (still) but today I'm gonna do the new plugs and just pray that it's fixed after
Old Nov 29, 2013 | 07:04 PM
  #56
Well I want to thank all of you guys for the help! I do realy appreciate and I'm greatful for the advice. I replaced the plugs and on 3, the tips were clean broken off and on 1 the electrode tip that curves was bent way to the side. I replaced the iac and the ignition module and she runs without skipping a beat!!
Old Nov 29, 2013 | 07:06 PM
  #57
BlackJet's Avatar
Car: 1988 Formula 5.7
Well alright Servo, good deal. Told you they would help you
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
