Part ID
Old Nov 25, 2013 | 12:18 PM
Pinguiclia's Avatar
Car: 1992 Camaro RS
Part ID
When I installed my Megashifter the instructions called to zip tie it down and forget about it, but when I was pulling up the carpet I ran into again and about halfway through it's pretty much rusted through. I know it has something to do with locking the key in when it's extended but that's about it. I was wondering if there is a way to delete this somehow? I thought of cutting it way up in the dash but I'm worried it'll lock the key up some random day. Any ideas?
Thanks,
Justin
Old Nov 26, 2013 | 04:14 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Part ID
Any ideas?
[/IMG]
the shifter interlock cable; means the shifter must be in P before you can remove the key from the Ign.
Unless you want to dismantle the steering column to remove the locking pin just tie the cable in the unlocked position
Old Nov 26, 2013 | 08:39 PM
Pinguiclia's Avatar
Car: 1992 Camaro RS
Re: Part ID
Thanks for the name, besides it being extended to lock the key do you know how else it operates? Does it pull that locking pin or something? Just curious to know how it works. As for tying it up my concern is that right about in the middle of it it's rusted out only held together by a few strands of the cable. If I snip it there and tie it up somewhere in the dash what are the odds of it slowly slipping into the locking mode?
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
