88 TA Gearbox AN fittings
Old Nov 28, 2013 | 01:47 AM
Marc Brown's Avatar
Hey guys,
Just wondering if you guys new of any kits that may work on a 88 Formula gearbox . I'd like to go with AN fittings and have found most threads on here that talk about the main pressure line using :
16mm x 1.5 to -6 AN (adapter for pump)
18mm x 1.5 to -6 AN (Adapter to Gearbox)
I'm understanding that this is for the High pressure side....
I can't find two things:
1. What kind of hose to use for High pressure side (I'm wanting to use a braided type hose)(AN style preferred)
2. What size is the return line on gearbox?
I have found this kit for 1980 and up: http://www.speedwaymotors.com/Gotta-...-Up,19959.html
but , can this kit be used on our cars. Just wondering. If you guys have any info or have done this , please inform me on how to do it.... and if I'm right on fittings for an 88 model gearbox and pump. Thanks again
Marc
Old Nov 28, 2013 | 04:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 88 TA Gearbox AN fittings
https://www.thirdgen.org/forums/tech...formation.html
Gearbox (trans ) or power steering
Old Nov 28, 2013 | 05:24 AM
Twin_Turbo's Avatar
I think he means the power steering pump and steering box. They re simply those metric o ring fittings you posted. The stering box takes a large and small one, the pump..no idea I never use stock pumps (only KRC pumps)
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
