Ignition switch help!!!
Old Nov 30, 2013 | 10:16 PM
MeanFbirdT/A's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: LG4 305
Transmission: Borg-Warner T5
Hey everyone, I'm buying an 84 junk parts camaro(has horribly underpowered 305, 2.73 non posi, a TH350, and a MILLION problems) that runs just to use in the winter and rob parts off of for a couple of things in my firebird. Anyway I test drove the car, went to go get the money and the went to start it to drive it off and the key broke off in the ignition, the key is now stuck in the off position, and the wheel is locked. I can put in a new ignition switch in the dash and re wire it, But PLEASE will someone tell me how to break the steering wheel lock. I don't care how its done, just some easy way to break it or disable it completely. Also if I remove the ignition cylinder will the wheel lock disable, or is it a different system? Someone please help, picture would be great.
Old Nov 30, 2013 | 10:25 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Just get the change out the ignition cylinder(it comes with keys) it's real cheap and doesn't take long to do
Old Nov 30, 2013 | 10:45 PM
Engine: LG4 305
Re: Ignition switch help!!!
If I swap out the ignition cylinder will it unlock the wheel? Can I even get it out when its in the off position?
Old Nov 30, 2013 | 11:28 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
I've never had to change one on a third gen, I've done one on a 78 Monte Carlo, I'm not sure if it has to be in the on or off or run position. Maybe another experienced member can chime in. Good luck!
Old Dec 1, 2013 | 12:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...ml#post3860471
Old Dec 1, 2013 | 07:44 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
When I changed mine about a month ago, I had to have in the off position.
Old Dec 3, 2013 | 11:44 AM
monkoskimike's Avatar
Car: 1988 I-roc
Engine: 5.7
Transmission: 700-r4
Axle/Gears: 3.73 posi
You could always drill out the ignition so long as it does not have vats
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
