reoccuring problem???
Old Dec 7, 2013 | 01:19 AM
mb2hurley's Avatar
Car: 91 camaro rs
Engine: v6 :/
Transmission: auto
91 camaro 3.1
i have to change my spark plugs around every 2 months because they foul out and my fuel consuption has gotten worse. ive changed almost all my sensors and a ruptured fuel pressure regulator. im wondering if i should look somewhere else.. im planning on pulling on my injectors and checking them, never done it before. know its pretty easy just check across the points. but what should they be reading and not reading?? and is there anything else to look at while im in there??
Old Dec 8, 2013 | 01:08 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: reoccuring problem???
You need to read resistance in ohms about 16ohms for the injector coil.
Check them cold and hot, but this will discover only a possible electrically faulty injector, those that pass the resistance test my fail a flow/pattern test.
If they are all fouling immeadiately after installation, the problem is common to the fuel delivery/control system.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
