Is this rebuild kit compatible?
Old Dec 8, 2013 | 12:58 AM
91z28dailydrive's Avatar
This is my very first engine rebuild and i have a 1991 camaro z/28 with the l98 350 and want to just do a stock or minor upgraded rebuild and was wondering if this kit is compatible with my motor....again im new to this and jegs and summit don't give me the information i want. thanks. http://www.summitracing.com/parts/fe...0/applications
Old Dec 8, 2013 | 04:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Is this rebuild kit compatible?
It is but you usually don't replace the pistons unless the engine needs boring out .
If it doesn't you typically just get the cylinder bores honed and fit new rings to your existing pistons.
If after being checked by a machine shop it needs boring oversize then you will need ( at least ) 4.030" pistons ; not the stock size 4.000" ones in that kit
Same with the crankshaft, it may be fine with new std size bearing ; if it needs grinding to clean it up then you would need different bearings to what is in that kit
Would be best to measure everything 1st before buying parts rather than waste $$$ by assuming
Old Dec 8, 2013 | 08:23 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Dec 8, 2013 | 05:23 PM
ok thanks for the information!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tonys91rs
Oct 10, 2015 03:31 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
