89 iroc-z dhutting off randomly
Old Dec 16, 2013 | 04:38 PM
87chevy350's Avatar
Hi, i am working on a 89 iroc-z for a guy. it has a 305 and 5 speed tranny. he said that when he is driving it randomly shuts off and is very inconsistent when it does shut off. he can not guess when its about to shut off. after it shuts off it wont start up until 5 minutes later. here is a list of things he changed or did:
tune up
fuel filter
distributor
Fuel injectors
Fuel pressure regulator
strainer/ float sending
Ecm (twice)
ignition switch
02 sensor
tps
egr valve
maf sensor
lac valve
ignition module
coil
2 relays
so can you guys help me out her and tell me what possibly it could be?
Old Dec 16, 2013 | 05:21 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 89 iroc-z dhutting off randomly
tune up
fuel filter
distributor
Fuel injectors
Ecm (twice)
ignition switch
02 sensor
tps
egr valve
maf sensor
lac valve
ignition module
coil
2 relays
so can you guys help me out here and tell me what possibly it could be?
Wow , that's one heck of a list ....
One question , when you state "distributor" , do you mean the cap and rotor or have you changed the entire distributor ? I ask because if you did only change the cap and rotor , and not the actual distributor itself , there is a "pickup coil" at the bottom of the distributor that your list doesn't specifically include , and that could cause your problem as well .
When it won't start , What's it NOT getting , Spark or fuel ? (If it cranks over with the starter , has proper compression , and spark + fuel , it should run)
Old Dec 16, 2013 | 05:36 PM
87chevy350's Avatar
Replaced the whole distributor. After it shuts off it starts up again but the idle goes up and down. when u hit the gas it shuts off. and when you start it up again the idle still will go up and down but when u hit the gas it would stay running. And the guy i am working on this for replaced all the things listed above by a garage and by his self. And now i am trying to figure this out for him. he took it to a couple of garages and they dont know.
Old Dec 16, 2013 | 05:38 PM
87chevy350's Avatar
I forgot to say it has proper compression spark and fuel. The car and motor has 76,000 miles thanks
Old Dec 18, 2013 | 01:43 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
I had the same problem. It sounds weird but I changed the wire going from the battery to the starter. problem went away. Go figure.
Old Feb 15, 2014 | 01:23 AM
Johngypsy's Avatar
Car: 1990 Iroc z
Engine: 5.7 liter Tune port 383 stroker
Transmission: 5-speed
Axle/Gears: 3.45
Did u find out what was the Proublem with the Iroc z??
I have the same exact issue and can't figure it out?
Please email me at: johnjohninht@gmail.com
Any time, please let me know what u find out,
Thanks so much,
John g
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
88CamZ
Oct 8, 2015 10:29 AM
Luigytico09
Oct 1, 2015 08:46 AM
ndndndnd
Sep 28, 2015 08:00 AM
