Factory oil pressure sensor and autometer gauge hook up. Possible?
Old Jan 4, 2014 | 06:46 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Ok I'm wondering if I can either hook up an autometer oil pressure gauge to a factory oil pressure sensor or hook up the factory oil pressure gauge to an autometer sensor.
Any ideas??
Old Jan 4, 2014 | 08:39 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Factory oil pressure sensor and autometer gauge hook up. Possible?
Need to know what resistance the Autometer gauge uses.
Some aftermarket gauges only work with their sender units
Old Jan 6, 2014 | 08:11 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
mechanical gages are more accurate.
install a 1/8 NPT brass "tee" fitting to the oil port location on the block, this way you can retain the stock electric gage sending unit and connect a mechanical gauge as well.
Old Jan 6, 2014 | 09:39 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The factory gauge has allows for a reading of 0-60psi on a resistance of 0-90 Ohms. 0 resistance is 0 psi and 90 resistance is 60psi. If the autometer gauge is set up that way you are golden. If the gauge goes over 60psi for sure no.
89GTAOz
May 16, 2020 09:31 AM
9192camaro
16
Feb 3, 2019 12:21 AM
db057
Aug 22, 2015 08:17 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
