Head gasket or intake gasket?
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
My car was losing a ton of coolant so I replaced the thermostat and put stop leak in my car. The car does hold coolant now but there is a wet spot on the ground and my oil doesn't look to good. But my car no longer runs hot or uses coolant. And it still has power. However I did notice my engine was wet on the front a few inches above the timing chain cover on the front of my intake. Could it be a bad intake gasket?
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Re: Head gasket or intake gasket?
did your coolant reservoir ever start to boil up? if so then its a head gasket for sure thats what happened to mine about 6 months ago
Yes it could easily be an intake gasket.
There is NO reason that it "for sure" is a head gasket.
Not a whole lot of sense in going for your own jugular. Calm down. Replace the intake gaskets. See if it fixes it. Only takes a few minutes.
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
