How can I tell if I Have a crossfire or 4Bbl
Old Jan 14, 2014 | 08:09 PM
fuzionbranz's Avatar
Car: Z28 1983
Engine: V8 5.0 4BBL
I recently bought a Camaro, I was just wondering from someone who knows motors well if this is a Crossfire or a 4barrel...So yeah could anyone tell me which?
1983 Z28
Old Jan 14, 2014 | 08:20 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: How can I tell if I Have a crossfire or 4Bbl
you have 4 barrelSome of the earlier 3rd gens in Canada did not have the ComputerCommandControl ECM controlled carb and distributor:had all mechanical carb and dizzy.
Old Jan 14, 2014 | 08:54 PM
Car: Z28 1983
Engine: V8 5.0 4BBL
and is these any way to tell which is it?
L69 V8
LG4 V8
Old Jan 14, 2014 | 09:07 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
originally it would have been an LG4-The L69 was offered in limited numbers starting in march or april of '83,the L69 differed externally from the LG4 in that it came with a dual inlet air cleaner housing and had an electric fan.If your car still has the original engine,it is an LG4 with 150 HP stock rating.
Old Jan 15, 2014 | 02:22 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Cross fire is dual single barrel TBIs and a special air cleaner assembly
you can start by removing the air cleaner lid. because all you are going to see is a single 4 barrel carburetor.
The engine model is on the VIN ...
Are these trick questions.
Try the Camaro "tech section" on the main page.
The 1983 L69 HO engine were only available with the Manual Trans... and since you do not have CFI you have the basic
LG4 Engine.
https://www.thirdgen.org/1983-chevy-camaro
NZKnight
Oct 15, 2015 02:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Tweeks25
Sep 17, 2015 08:04 AM
edoff13
Sep 11, 2015 03:55 AM
