New Plug Gap for 350 with Mods
Old Jan 29, 2014 | 12:40 PM
Danspeed1's Avatar
Car: 1986 Camaro Iroc Z
Engine: 5.7L Corvette L98
Axle/Gears: 2.73 Open
Hello,
Have a plug gap question; and unfortunately not alot of information. But I am hoping someone has the experience to make a good judgement call. Have a 1990 L98. Motor was recently rebuilt by my engine shop. Stock bottom 350 with new bearings, heads are the Corvette L98 heads that have been ported and polished. Valve job, new springs, lighter pushrods, 1.6 roller rockers. Cam is a stock 1990 Corvette Cam, that has been tweaked. The guys who built it are pro's but they are old school. Rather than plugging in a new cam they degreed the old one different to move the powerband up. Will be running a TPIS 1204 Intake,.... if I can find one for sale in the near future. MDS 6AL Ignition on a Jegs Distributor with a blaster 2 coil. Car originally called for FR5LS copper plugs. Engine is supposed to make 420Hp. I jumped down to FR3LS copper delco's (2 steps colder). Where do I set the gap?
Thanks,
Dan
Old Jan 29, 2014 | 01:17 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: New Plug Gap for 350 with Mods
.040 is a good baseline.
Old Jan 29, 2014 | 01:39 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Agreed. That's my default for most N/A setups.
Since you have the more powerful CD ignition, one could argue that it will handle a .050" gap or more, but it wouldn't make any more power, just a tiny improvement in idle quality/emissions.
Old Jan 29, 2014 | 08:11 PM
Yes.
You should DEFINITELY have some gap.
On the list of things that REALLY MATTER, how much gap is somewhere between about #173 and #452.
.040" is fine. .035" is fine. .045" is fine. Any more than that, all you accomplish, is stressing the other high-voltage components (wires, cap, rotor) unnecessarily. Any less, gets too easy to foul.
So, yeah.... make sure they have some gap.
Old Jan 29, 2014 | 09:26 PM
Danspeed1's Avatar
Thanks! .040 it is
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
69 Six Pack
Oct 5, 2015 07:51 PM
NWAsonoma
Aug 18, 2015 05:45 PM
