92 Camaro RS Turns but won't start.
Car: 92 Camaro RS
Engine: 3.1L V6
Transmission: Automatic
Very upsetting. I've had this car for about a month. Ran beautifully for a about a week, then one night after work I couldn't start it, haven't been able to get it to fire up since. When I turn the key it sounds like the fuel pump is getting to work, I've checked for a bright spark, checked for fuel pressure, changed the distributor. After that, I took a look at the trouble codes and just got 12's followed by no other codes. I'm about outta of things I know how to do. Any suggestions on how to get her started. I've already lost my job because I couldn't make it to work. Thank you!
Car: 92 Camaro RS
Engine: 3.1L V6
Re: 92 Camaro RS Turns but won't start.
No, it cuts off as soon as I start to crank it. I was warned of that problem with the security system because of my worn out key, but 90% of the time it would start. She definitely turns over, just no fire.
Car: 92 Camaro RS
Engine: 3.1L V6
I will try wiggling it as a crank it, but i have moved the car the day after it stopped starting to tow it to my house. I will post the results.
92camaroJoe
Aug 13, 2015 06:07 AM
