Random no start (I searched already)
Old Jan 31, 2014 | 12:11 PM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Ok, so i hunted through a bunch of threads here but still haven't come up with a definitive solution.
I have an 87 GTA, (no vats) and all of a sudden she is having random no start issues. Doesn't matter cold or hot. She has done it three times in a row, and then not for a week, completely random. And I can turn the key all the way, fuel pump comes on, lights everything just no crank, doesn't even try. She will, however, bomb start every time.
I have my neutral safety switch bypassed so I know that is not the issue, since I drove her for 2 years with it like that.
Only thing that has been done lately is a new ignition cylinder was installed because it stopped turning to the crank position. But she ran for almost 8 months no issues? This just recently popped up as an issue.
Anyone else had anything similar? that didn't end up being the neutral safety?
Thanks Guys
Chelsea
Old Jan 31, 2014 | 12:47 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Random no start (I searched already)
When you say neutral safety switch, do you mean the switch that is engaged when you press the clutch to start it? (your sig says it's a 5 speed so I'm assuming that's what you mean).
If so I would advise you to check the bypass you put in, make sure all the wires are still good. I had that switch bypassed on a 5-speed cavalier for a while but it still went bad and needed some attention at one point.
Old Jan 31, 2014 | 05:18 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Yes, that was what I meant and Its basically hardwired so no chance of failure there.
Old Feb 18, 2014 | 05:38 PM
DKIRCH26's Avatar
Car: 89 Trans-am
Engine: 305 tpi
Axle/Gears: stock
Mine just started doing the same thing. Have you been able to figure yours out?
Old Feb 18, 2014 | 07:14 PM
Next time it does it, have your assistant turn the key to start and hold it, while you get underneath the car and whap the starter with a tire tool or something.
If it starts when you hit it, you need a starter.
It'll do nothing but get worse as long as that starter is in there, if it has that problem.
Old Feb 20, 2014 | 02:59 PM
zak muroc's Avatar
Car: 1991 trans am firebird
I really hope someone knows what the heck the problem is! lol I tried putting in a new starter today and I tried to crank it up when I was all finished and bam! all I heard was the fuel pump turn on and no engaging of the starter. What a waste of time and $$ that was. Then I let it sit for about 5 minutes ... went to try again and it cranked right up. Just about every time I go to crank up the car it'll do this. So it's only going to get worse , it'll eventually do this every time you go to turn the key. SOMEONE HELP! ha
91 5.0 TPI
Old Feb 20, 2014 | 03:02 PM
Car: 1983 Z28
91 5.0 TPI
I'd suggest starting your own thread on this so as to not hijack someone else's who may or may not even have the same issue as you.
Old Feb 20, 2014 | 03:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Only one way to find out
It is a very simple circuit
see
http://92b4crs.tripod.com/86wiring/dia-pics/30-2.jpg
so get the DVM out and find where you are loosing power to the solenoid
Start by checking for power on the purple wire at the solenoid.
If you have power there in the START position then the starter is suspect as Sofa suggested
If no power check yellow wire out of the Ign switch
Ghettobird52
Jul 5, 2024 11:18 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
