Heater core Bypass---Quick connect?
Old Jan 31, 2014 | 01:48 PM
LoganKello's Avatar
Car: Trans Am GTA
Hi guys,
So this spring I am going to bypass my heater core in my 91 TA. Passenger side carpet seems like it is wet a lot. I don't think its the T-tops leaking but I could be wrong. Wanting to bypass the heater core to see if that is what is leaking...which would explain the loss of coolant in my radiator over a few months.
So, when I disconnect both heater hoses from the intake and output for the heater core, what will be best to connect them to ensure optimal peace of mind? Is there a certain size quick connect that I should use? I assume metal is going to be better than plastic?
....I just want dry carpet
Old Jan 31, 2014 | 02:13 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Heater core Bypass---Quick connect?
Originally Posted by LoganKello
Hi guys,
Hi LoganKello ,
As long as you have been using 50/50 antifreeze instead of pure water , this one is really easy to diagnose . Rub your hand across the wet carpet a few times and then feel your fingers . Got a wet sticky gummy kinda gross feeling to the dampness , well then it's coolant . If it just feels damp , with no creepy feels like somethings soaking into your skin feeling , it's likely water . It's kinda like that same feeling ya get when you get brake fluid on your hands , you can tell it from pure water right away ....
OOps , forgot to answer the actual question .... Most times I've seen heater cores looped out they just used an appropriatly sized plumbing elbow of the metal variety , one that had one side somewhat larger than the other to make up for the difference in hose sizes .
codeysabatini
Nov 10, 2015 04:07 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
gta892000
Sep 16, 2015 12:37 AM
