1992 TPI Camaro 305 to 350
Old Jan 31, 2014 | 02:25 PM
camaroclint's Avatar
Car: Chevy Pickup
Transmission: muncie
Axle/Gears: 373
Hi Guys I need some help here. This is what I got. I put a 350 in the 92 Z28 I have.I used the tuned port set up off the 305 that was in the car .I installed 350 injectors and a 350 knock sensor.I have a zz4 camshaft in it.Pcm burnt me a chip for it. The problem is when I start it, it idles ok but surges until its warmed up.when after its warm I cant get the idle down it seems like its around 1500 the tach doesnt work well so its hard to tell. I have cleaned off the icm and reinstalled it. timing is on the mark and the car runs great just the idle is so high.The idle adjustment screw is all the way back and doesnt make contact so i cant adjust it there. Any help would be appreciated, Thanks guys !
Old Jan 31, 2014 | 02:27 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 TPI Camaro 305 to 350
Sounds like a vacuum leak or stuck iac. I would doubt the target idle vs coolant temp would be set so high.
Old Jan 31, 2014 | 02:41 PM
Engine: Lb9
Transmission: M20
btw, not sure if you are following the correct procedure to set the minimum idle speed setting with the iac commanded in.
Old Jan 31, 2014 | 06:57 PM
Car: Chevy Pickup
Axle/Gears: 373
I had sprayed staring fluid over the induction system and the idle didnt raise, and it seems like it idles fine when its cold.I am not sure how to set the idle speed? does it need reset in some way? I did have to egg out the bolt holes on the manifold to get it on but it seems like it is sealed and looked like the ports all matched up . Thanks for your help.
Old Jan 31, 2014 | 07:33 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/tpimod2
a scanner will allow you to see the target rpm and iac steps.
Old Feb 4, 2014 | 08:45 PM
dukes9009's Avatar
Car: 87 Chevy Camaro Iroc Z Z28
Engine: 305 tpi to 350 tpi
where did you get the motor? I planning to do the upgrade also you any advice.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
st.evel07
Aug 13, 2015 06:15 PM
