Single to dual snorkel swap
Old Feb 13, 2014 | 04:42 PM
Rainmaster's Avatar
Car: 1987 GTA
Engine: LB9
Axle/Gears: 10 bolt 3.23
Hello all,
I am going to be upgrading from the LG4's single air cleaner to a dual air cleaner from an L69. On the single air cleaner there is a hose/tube on the underside of the inlet which connects to valve cover on on the driver's side. The dual snorkel housing, I believe, does not have a place to connect this hose/tube to. My question is this: what do I do about this hose/tube or the opening in the valve cover? From the research I have attempted to do, it seems this is some sort of breather valve but I'm not sure. I can get pictures of what I'm talking about tomorrow if they're needed. Thanks for any help in advance.
-Ryan
Old Feb 13, 2014 | 05:47 PM
Re: Single to dual snorkel swap
It does.
Everything hooks right back up, just the same as it was.
Old Feb 13, 2014 | 05:53 PM
Rainmaster's Avatar
Car: 1987 GTA
Engine: LB9
Really? Hmm... I guess it's hard to tell from the pictures I've seen. Thanks for the reply.
Old Feb 13, 2014 | 06:38 PM
gt4373's Avatar
Transmission: 5-Speed Manual
[QUOTE=Rainmaster;5714566]Hello all,
-Ryan[/QUOTE
You Are Correct,The Only Hose/Tube On The Driver's Side That Connects To The L69 Air Cleaner Is The Heat Tube That Connects To The Heat Stove On The Left Exhaust Maniford.
Old Feb 13, 2014 | 06:47 PM
The L69 preheater tube is on the pass side exh man. So if yours is on the driver's side, you'll have trouble with that.
Wouldn't be too hard to fab up some kind of simple heat stove to go around the pass side one if that's the case. All it does, is close off the main ducts when the engine is cold and open up that one, thus forcing all the intake air to pass over the exh man before getting to the intake. Not a real tough thing to duplicate adequately.
Old Feb 13, 2014 | 07:34 PM
Rainmaster's Avatar
Car: 1987 GTA
Engine: LB9
Oh I see now. For some reason I thought that it connected to the valve cover rather than the exhaust manifold. And thanks for the picture, I can't seem to find any that clearly show how it looks there.
customblackbird
Aug 15, 2021 10:16 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
krisner89
Oct 10, 2015 06:03 AM
beastin91rs
Oct 9, 2015 07:38 AM
