Wont Start
Old Feb 16, 2014 | 09:03 PM
tri power's Avatar
Wont Start
Have a 90 TPI motor it has new injectors, new distributor, and new computer car cranks and runs then it will just die by itself will not crank spins over and is trying to crank checked fuel pressure it is 40-45 changed knock sensor when the car runs a few minutes and heats up and is cut off will not start back tries to start but will not. HELP
Old Feb 16, 2014 | 10:45 PM
John62591's Avatar
Car: '83 Camaro Z28 5.0, '93 Camry 3.0
Engine: 305 V8, V6 DOC
Re: Wont Start
Maybe its overheating, or the computer thinks it is...
Old Feb 17, 2014 | 02:45 PM
John62591's Avatar
Re: Wont Start
Couple questions, Is it cranking slowly or fairly fast?
Do the lights dim, stay bright, or go out when cranking?
Is there gas in the tank?
Does your security light come on or blink?
The fuel filter may be clogged, the battery could be run down, temperature sensor could be bad. There are many things that can prevent your car from starting.
When you go to crank, just observe as many things as possible with what the lights on the dash do, any abnormal sounds, or feel abnormalities in the gas pedal.
Post here with any more info so we can narrow down your issue/s
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
